q7plus
Roborock Q10 Series
Uncompromised Excellence
Q10 Series
Q10 Series
10,000 Pa
HyperForce Suction
Q10 Series
Dual Anti-Tangle System
Q10 Series
VibraRise 2.0 Mopping
System
Q10 Series
Auto Lifting Mopping
System
Roborock Q10VF
Roborock Q10VF+
Q10 Series
ReactiveTech Obstacle
Avoidance
Q10 Series
PreciSense LiDAR
Navigation
Q10 Series
Self-Emptying Dock
Q10 Series
Flexible App Control
Available in 2 Options
Roborock Q10VF
Roborock Q10VF+
Impressive HyperForce Suction Power
Root Out Hair From
Crevices and Carpets
Suction Power
Root Out Hair
From Crevices and Carpets
Q10 Series
Q10 Series
HyperForce Suction Power 1
Q10 Series
Fewer Tangle. Fewer Trouble.
Dual Anti-Tangle
Design
Q10 Series
Q10 Series
JawScrapers Comb
Anti-Tangle Main Brush
Hair Tangling on Side Brush 2
Removes Dust You
Hardly See
Q10 Series
Roborock Q10VF
VibraRise 2.0 Mopping System
The VibraRise 2.0 Vibrating Mop System uses advanced vibration technology to tackle stubborn stains with ease. It efficiently lifts tough dirt and grime, leaving your floors spotless.
3000 times/min
Vibration Frequency3
8mm
Mopping Module Lifting3
Dual-Zone
Active Vibrating with Reduced Water Stain
Q10 Series
Roborock Q10VF+
Auto-Lifting Mopping System
The Auto-Lifting Mopping System automatically adjusts to carpets, providing a thorough clean with ease. Enjoy efficient, effortless mopping for consistently spotless results.
8mm
Q10 Series
Ready to Avoid
Troubles, Every
Time
Powered by structured light, this advanced system effortlessly detects and navigates around obstacles, even in cluttered rooms with items scattered across the floor.4
Q10 Series
Q10 Series
PreciSense LiDAR Navigation
Learn, Navigate,
Remember
Q10 Series
Q10 Series
RockDock Plus
Handles Dirty
Work for You
Q10 Series
Experience hassle-free cleaning convenience with the RockDock Plus. The large dust bag lets you clean for up to 7-10 weeks without emptying5, making it ideal for families with pets and reducing allergens.6
Q10 Series
Tap, Tap, Clean
Q10 Series
Q10 Series
Temporary Cleaning
Temporary Cleaning
Q10 Series
Auto Boost on Carpet
Q10 Series
High-Intensity Mopping
Q10 Series
Cleans Along Floor Direction
Q10 Series
Temporary Cleaning
Temporary Cleaning
Q10 Series
Q10 Series
Q10 Series
Roborock Q10VF
Robot Vacuum
353 * 353 * 99 mm
160 * 70 * 101 mm
Roborock Q10VF+
Robot Vacuum
353 * 353 * 99 mm
212 * 178 * 259 mm
  • 5200mAh Battery Capacity
  • Customizable Cleaning Modes
  • Off-Peak Charging
STAY TUNED IN!
2. Based on testing carried out by TÜV Rheinland. For anti-hair entanglement in different modes, the certification no. is CN251UKF 001. The pet hair tangle rate is 0%, while short human hair tangle rate is 0.063%. Actual results may vary depending on usage conditions.
4. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
