Series
2x
20%↑
Introducing the DuoRoller Brush, the latest in Roborock’s cleaning technology, designed to enhance vacuuming performance on carpets, ensuring fewer hair tangles, and providing a hassle-free cleaning experience.
HyperForce suction power has been upgraded to 5,500 Pa2, allowing Q8 Max to easily remove dirt and pet hair from different types of floors, leaving you with a spotless living space every time.
Water Flow Options
for Versatile Cleaning Needs
PreciSense LiDAR Navigation creates detailed and accurate maps, enabling the Q8 Max to identify the most efficient route to navigate and optimally clean your home.
Quick Mapping3
Map Display
Mapping System4
Maximum Runtime6
Maximum Vacuuming Area6
*RockDock Plus is only available with the Roborock Q8 Max+.
Customizable App Features
ScratchSafe Wheels and Brushes
Sensient Sensor Array
Adaptive Route Algorithms
Child Lock
Off-Peak Charging
Robot vacuum
