3-Stage
Room-temperature air drying keeps both the mops and dock fresh, preventing odors and maintaining a hygienic environment, so your home stays as clean as it looks.
45dB
The dock’s dust bag automatically empties the robot’s dustbin, letting you go up to 7-9 weeks without manual emptying, giving you long-term convenience. 4
65 days
99.90%
HyperForce® SuctionExperience this veritable cleaning powerhouse with its 10000Pa HyperForce® suction. Whether it's hard floors or carpets, it proficiently extracts deeply embedded dirt and dust, guaranteeing a spotless clean with every use.
Hair Tangling7
200RPM
10mm
30 Levels of
Scans quickly to know your home environment and creates detailed maps to find an optimal route to clean your home.
6x Faster
3D
Multi-level
Fully charged
After Meals
350*353*96.5mm
340*487*519mm
Roborock QR 798
Roborock Qrevo 5AE
1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021 / 5.11 standards, using Max+ mode with a full battery, the maximum suction power can be up to 10,000 Pa. Actual results may vary due to environmental factors. Suction power values may vary by country or region.
3. Based on internal testing carried out by the manufacturer, the noise level when drying is as low as 45dB in a semi-anechoic chamber. Actual noise levels may vary due to environmental factors.
4. Based on Roborock internal testing. Actual performance may vary depending on home environment, cleanliness level, user habits, and other factors.
5. Based on internal testing carried out by the manufacturer. The actual emptying interval will depend on user habits and environmental factors.
6. Certification No.PT/23/GEN/0046 by SGS (product code name:RRW0PEP). Actual results may vary depending on usage conditions.
7. Certified No.PT/24/GEN/0454/1 by SGS (product code name:RRW0PEP). Actual results may vary according to the home environment.
8. Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed of 200RPM.
9. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10mm. Actual results may vary depending on environmental factors.
